Hose Choice for Draining
Van G
264
Toronto
Fiberglass
Hayward Aqua Rite (T-15)
I've been using 100' 5/8" hose connected to sub-pump which has 3/4" adaptor.
I can get 1 1/4" or 1 1/2" I believe. Pump is 1/2 hp (3k gph I think).
Should I just buy 100' of 1 1/2" heavy duty backwash hose (clamp on) for the fastest drain rate?
I only have to take water out a half dozen times a season so the compactness of lay flat hose is appealing.
A larger hose will give you a greater flow rate out of your pump.
See how long the backwash hose lasts.
Your 5/8” hose is restricting your flow significantly. Larger diameter will provide a higher flow rate.
I just use a short length of hose like 10 feet connected to the hose bib on my pump. It's slow but I don't care I start it when I start cutting the grass and by the time I'm done, it usually is as well.
"Your 5/8” hose is restricting your flow significantly. Larger diameter will provide a higher flow rate."
Agreed. Will 1 1/2" heavy duty backwash hose last if cared for properly?
Like this?
