Hi, I'm new to the site and than you for any help you can provide!
I have 30k, in ground, salt water, liner pool. My CYA is 116.
I need to drain my pool based on the tfp calculator by a significant amount. I have started to drain, but the way my house is set up the water shoots out a tube next to my pool equipment. It runs until it gets below skimmer and then the pumps shut down. Unfortunately the water immediately rolls back toward the the house and foundation...it doesn't normally do this when it rains, but the amount of water from the pool overwhelms the French drain
I was curious if there's some kind of adaptor I can use to connect a hose and diver the water further away.
Thank u in advance!!!
