- Jul 16, 2022
- 18
- Vinyl
- CircuPool Core-55
Does anyone know of a HomeKit compatible toggle switch that I can use to replace the hi/low/off toggle on my 2 speed pool pump?
I currently have the power supply for both my pump and swg plugged into a smart plug to automate the on/off cycle.
The goal here is to be able to automate a cycle from off > on high > on low > on high > off in order to save electricity over the daily 10hr run time needed for my swg to maintain FC but also allow a couple hours of really good skimming on the high setting at the beginning and end of the cycle.
Picture of both pump plate and toggle switch wiring diagram are attached.
FYI - The plugs for the pump & swg are currently both on the same GFCI, plus the automation and iphone on screen “button” script o have written are set so that the swg cannot be on unless the pump is also on, just in case the low-flow switch inside the swg malfunctions.
Thanks in advance for any tips or advice!
