So alongside our holiday let hot tub we got our own recently.
We can obviously run this for longer, not having to empty it every 3 days or so.
So far so good I thought. Water has been in about 4 weeks so far, and have maintained Chlorine and pH correctly. (I aim for about 3ppm. It’s dropped to 1.2 but never to zero. pH 7.2-7.8. CYA is up to about 40 now so using bleach)
However… I was sending off a microbiological sample for our Hol Let tub (legal requirement) so thought I’d sample our tub too
Results are mostly fine but I’m concerned about the TVC:
TVC @ 37c = 1920 Cfu/ml
Chloriforms = 0
Ecoli = 0
Pseudomonas = 0
S Aureus = 0
Our regs say TVC (Total viable organism count) should be less than 100 ideally
what could be causing this in a relatively new hot tub with a filter and correct Chlorine and pH?
I did wonder if some of the “new filter” dirt got in but surely that would be filtered out. We’ve had a couple of sessions with 4 adults in the tub but always thrown either a DiChlor or bleach in after.
I’ll probably empty the hot tub, clean and refill but ideally wanted to keep it running longer.
Chloriforms = 0
Ecoli = 0
Pseudomonas = 0
S Aureus = 0
