So I'm new to the crew here and probably been onboard with the TFP method for probably 1 month. For the last 4 weeks the only thing I had added to my pool has been liquid chlorine to maintain the correct FC ratio and then sodium bisulfate to bring down the PH. The Ph tends to creep up and normally sits around 7.8 on my pool. My TA is high which doesn't help. Yesterday I finally got my hands on some Muriatic Acid and switched to that to bring Ph and TA down. I added about 1/3 of a gallon and Ph dropped within the hour from 8 to 7.6. This morning I check and the Ph is already back up to 7.8 and the TA didn't seem to move much. My TA is 190. So today I added about another 1/3 of a gallon of the muriatic acid.
My question is do I just keep adding muriatic acid to drive the Ph and TA down? I added the amount that pool math suggested but clearly didn't get the response I was expecting. When testing this morning I didn't really see much reduction of TA. What kind of timing should I expect on continuing to drive and get my Ph and Ta down? I am in North Texas and the head and humidity has been very high, so the pool has been adding makeup water.
