"bun", we had to move that post back to this thread to prevent a hijack situation, but it's okay. This way we can focus on you. It is somewhat common for members in your area to have an exceptionally high TA. I've seen some well over 400. Not to worry. As long as your pH is stable, nothing bad will come of it. Over the course of the season the TA will slowly fall with each acid application you use to control the pH. You don't really have to go out of your way right now to lower the TA, but when the pH does get high, say about 8.0, then use enough acid to lower the pH to about 7.2. Each time you do that it will lower the TA a little at a time.
