High TA but pH holding steady
Jul 27, 2017
14
Saginaw MI
Wondering if I need to lower TA in my situation. Test results are:
FC 4.4
CC 0
pH 7.4 (has held steady since we put up the pool 2 weeks ago)
TA 100 (water turned clear at 90, pink at 100. So maybe 95?)
CH 130
CYA 70
since the pH has been holding steady and we're taking down the pool in 6 weeks anyway, I was thinking the TA is not a big deal. Is there some other reason to lower the TA that I'm not considering?
I Really appreciate the great advice I've been getting here!
If you pH is stable ther eis no reason to adjust you TA. If your pH does start to increase, the acid that will add to correct it will also lower the TA. Just repeat this procedure until the pH stays put and that will be your new target TA level.
I wouldn't worry about the TA so long as your pH is stable
I would definitely raise your chlorine level with a CYA of 70 to 8-10 as in chlorine cya chart
OP has a SWG pool, FC target at 70ppm CYA is 5ppm.
[FC/CYA][/FC/CYA]
As mentioned, don't worry about the TA if your pH is stable.
