Hi, I've got a high-pressure switch in my Aquacal Heatwave SQ110 with a damaged wire. The correct replacement part according to Aquacal is STK0074, though the original was RES0018, but I've had trouble sourcing the replacement part. This part is the same one used to replace the switch in newer models too.
It's 600CO / 445 CI. Any idea what part I can use in it's place? I found some various switches on Amazon that are similar but not 100% a match, but wondering if there is a known / preferred solution for this.
