Probably a stupid question: what does 5ppm mean? Lol, I usually just pour in the gallon. And if the chlorine is high, wouldn’t this raise it higher?Welcome to TFP!!!
The first thing to do is get your own test kit! Link-->Test Kits Compared
Add 5ppm of liquid chlorine per day until you test kit arrives. Nothing else.
Post a full set of results with your kit and we'll get you going!
Yes. I like 3 ppm better than 5 ppm for you. You have clear water and daily demand isn't crazy in Chicago yet.So, I need to add 48 oz per day until the testing kit arrives, correct? Which is Friday)
Nope. Stay the course.Anything else I should do until I can test it?
Here are the results when I tested with the Taylor Kit Hopefully, I did it correctly but I did have my adult daughter there helping to verify Any guidance would be appreciated!Skip the block test for FC and only use the block for Ph
Use 10ml samples for FC and each drop is 1/2 FC.
Use 10ml samples for CH and each drop is 25.
You did GREAT.Hopefully, I did it correctly
You're sitting pretty. The high TA will make the Ph rise rather quickly, but everytime you lower the Ph (Use muriatic acid and PoolMath). The TA will come some and eventually settle on its own.Any guidance would be appreciated!
Did the overnight test. Last night FC was 5.5-6 ppm. This morning FC is 5ppm so I assume I am ok there. What are my next steps? Use Pool Math ( for how much Muriatic acid) to bring the PH down to low 7s and then once TA comes down, PH should be high 7’s?You did GREAT.
Maintain a low 7 ph until the TA is under 100, then switch to the high 7s and dose back to a high 7 whenever it's 8+.
Being that this is the first the pool has seen of TFP, it's a wise choice to do an overnight loss test to ensure you're algae free. It's microscopic and you can't see it until it's waaaaaaaaaay too late. Testing let's us see what our eyes can't.
Overnight Chlorine Loss Test
