9000 gal above ground salt water pool. CYA 80. TA 90 Salt 3600 Ph 7.8 (lowered to 7.5 w/muriotic acid) FC 5 (trying to maintain 6-8ppm). Replaced the SWG cell last season rated to 20K gallons. DA bump style filter. The pump runs 24/7 at 55% and then bumps up to 90% when heat is in use. I use a heat pump to maintain 85 degrees. I have my SWG set to run 12 hours at 70% and I can’t maintain FC. Ph keeps creeping up and I’m not aerating. Once I lower the Ph and set the SWG to 100% I can bring the FC back to where I want it. Heavy pollen in the pool the last few weeks. No algae blooms water is crystal clear. Am I missing something?
