high PH and TA - raise TA?
newbiepo0lowner
Active member
May 19, 2021
34
Sacramento, CA
Hi,
I tested the water this morning and most numbers seems to be pretty normal since our last few test other than having to regular add liquid chlorine. Our PH seems to be on the higher end every time we test in a few weeks and have been throwing muriatic acid to bring it down to 7.5 before swimming. I see my TA is lowering and I know that is expected when bring the PH down.. but wondering if I should I work on bringing the TA higher closer to 100 and see if that stabilizes the TA?
FC 9
PH 8.2
TA 70
CH 325
CYA 50
Thank you!
