I have a plaster in-ground pool with high CYA levels that, as I understand it, is rendering the chlorine ineffective. I understand that to get the CYA level down I have to remove and replace water from the pool. My question is where does the CYA concentrate? Do I remove the top 2 feet of water with the pump on a ledge, or the bottom 2' of water with the pump on the bottom?
