We have had several members test Bio-Active and the results were less than satisfactory. It only worked for a couple of people, and even then they saw maybe a 20ppm drop in CYA, and second applications saw no further reductions. The conditions it works under are difficult to identify and replicate. You can type "Bio-Active" in the search bar to pull up those threads if you would like to read them. It is probably cheaper and more efficient to just replace water than to use Bio-Active.
