We just put up and filled our pool over the last few days. If it matters, it’s 16’x48”, above ground. Before adding any chemical, we tested the water and CYA levels show to be 300 on a test strip. For what i’ve managed to find online, tap water shouldn't have CYA in it. Is it possible that something else is cause a false reading and the CYA isn't really this high?
The TA is 240
PH is 8.4
TH is 0
FAC is 0
These numbers are all from untreated, just filled tap water. I know i’ve got to get everything in range but just trying to figure out where to start.
The TA is 240
PH is 8.4
TH is 0
FAC is 0
