Hi! I bought a house with a pool this spring and thought everything was going well until our cya levels rapidly escalated over the last couple weeks. (The feeder was going through trichlor tabs so fast, it was keeping the FC level between 7-11ppm even when I tried turning it all the way down). A few days ago I stopped using the feeder (started using skimmers) and today I bought non-stabilized chlorine tabs (sodium hypochlorite) and don't ever plan to use trichlor again.
Today's test:
FC 3
CC 0
pH 7.6
TA 100
CH 180
CYA >100 (the dot disappeared about halfway to 100)
The water looks clear but I have some yellow/green algae that keeps trying to grow along the southern wall and steps (I have been brushing/vacuuming it off for the last couple weeks but it keeps coming back).
My husband wants to go with the pool store recommendation of adding a copper algaecide (they told him not to shock). I want to try shocking/slamming but don't know how high to go since I don't have an accurate CYA value and I read that I need to get the CYA down before slamming anyway.
I drained and refilled about 3 inches today but I feel bad doing this on our well and with our CYA so high I feel like it won't make a difference anytime soon. The pool store said to give it a few months and never drain more that a foot to preserve the plaster... Is it really safe to drain half the pool or should I try draining and filling simultaneously to swap out the water?
What do I do in the meantime while I try to get there CYA down? Can I shock and how do I know how high I need to get the FC?
Thank you!
Today's test:
FC 3
CC 0
pH 7.6
TA 100
CH 180
Thank you!
