- May 3, 2014
- 58,690
- Fiberglass
- Pentair Intellichlor IC-40
For the stains it would be best to do the treatment now so you would drain off the iron when it is back in the water.
Wait several hours and brush the pool or swim to fully mix the water. Then retest.
I would err pH on the low side. Much worse to have too low of pH versus too high a pH.
Hi Ejosh87,Ok did another test (5 hours since stopped drain/fill) and showing:
FC: 12
PH: 7.8
TA: 100
CH: 300
CYA: 50 (hard to tell exactly but 50-60)
So assuming at this point I'll just let FC come down to 4-8 range and then start with Liquid Chlorine daily to keep it in that range.
Thanks so much for everyone's help.
Hi Ejosh87,
Where did you end up placing the pump?
Thanks
