Since having a new VSP plus filter installed last month it has been one problem after another. The GFI circuit has tripped MANY times starting the day following the install. When we are home we untrip it. When we are away for a couple of days and it trips we are returning to no chlorine since the pump and hence, the SWG wasn’t running. My chlorine levels have bounced from zero to 16ppm. At 16 this morning. Turned the SWG down to 40%. A tech is coming Tuesday to look at the electrical. Unfortunately we leave the next day for 10 days and would like to come back to a clean pool. These are the test results this morning:
Free CL 16
Comb CL .5
PH 8
ALK 90
CA Hardness 370
CYA 90
Salt 3300
Should I just let the chlorine burn off? I am in FL so it is plenty hot. What can I do for cloudiness?
Free CL 16
Comb CL .5
PH 8
ALK 90
CA Hardness 370
CYA 90
Salt 3300
