I have a cheapo inflatable hot tub. Have been outta town and a buddy came by while I was gone to put some chlorinating liquid in.
Tested water today, and results were strange. Chlorine showed fuchsia/purple and never went clear. PH was purple and acid demand reagent changed it to blue. TA was some off color and never turned red. CYA appears to be approximately zero. Water is clear. Temp around 100F.
As I understand it, chlorine numbers being high will affect test results. HOWEVER, not too sure how to fix that right now. Just wait a while for it to drop down?
I have a pool as well. This hot tub is only a few hundred gallons so wouldn't be a big deal to drain and refill. Could even dump the water into the pool and refill with pool water which is balanced just fine. I'm mostly just curious about how one might go about actually fixing this water chemistry issue. Other than not letting my buddy dump so much chlorine in it next time
