I have a Pentair system that is losing prime and getting a lot of air in pump basket. I replaced the pump basket o-ring. Then replaced the 3 inch and 1 inch o-rings on the valve. The air disappeared and the pool clearer came back to life. Then on the next cycle the air was back. I replaced the 1 inch o-ring again and worked great for one cycle only. Now pool won't prime. Should I replace the valve, it has a actuator.
I have had the pool turned off for awhile and I notice the spa water level has dropped. Maybe that has nothing to do with my air in system problem?
