Prices from In the Swim:
Trichlor $359 for 50 lb. = 7.18 per pound, will raise FC by 10 per lb. So,
$0.718 per FC. Each pound will also raise CYA by 6ppm.
Dichlor $217 for 40 lb. = 5.425 per pound, will raise FC by 6 per lb. So ,
$0.904 per FC. Each pound will also raise CYA by 6ppm.
Cal-Hypo (68%) $260 for 50 lb. = 5.2 per pound, will raise FC by 7 per lb. So,
$0.742 per FC. Each pound will also raise CH by 5ppm.
Liquid chlorine is $6 / Gallon at Walmart = 9.1 FC in your pool, or =
$0.66 per FC.
Circupool RJ-20 is $1300. (
CircuPool RJ-20 PLUS Saltwater Chlorinator | Discount Salt Pool)
Outputs .9lb / day = 9.8 FC / day in 11K pool.
Lifespan of 15,000hours = 625 days at 100%
625* 9.8 = 6,125FC
$1300/6125 =
$0.21 per FC.
Even if the cell lasts only 7500 hours, it is still
$0.42 per FC.
SWG is the cheapest, liquid next and solids are the most expensive. This is not including water cost with the solid forms of chlorine.
