PoolStored TFP Expert Gold Supporter TFP Guide Jun 24, 2021 16,496 Ashtabula, OH Pool Size 29000 Surface Vinyl Chlorine Salt Water Generator SWG Type CircuPool RJ-60 Plus Today at 10:28 AM Add bookmark #421 It’s 40 then.
HermanTX Gold Supporter TFP Guide May 20, 2020 7,985 Austin TX Today at 10:29 AM Add bookmark #422 Maldravus said: I edited my post - I meant to say 30 not 40. So it is somewhere between 30 and 60. Click to expand... If you could not see the dot at 30 but can see at 40 then it is 40
PoolStored TFP Expert Gold Supporter TFP Guide Jun 24, 2021 16,496 Ashtabula, OH Pool Size 29000 Surface Vinyl Chlorine Salt Water Generator SWG Type CircuPool RJ-60 Plus Today at 10:30 AM Add bookmark #423 Reread this: CYA - Cyanuric Acid Test Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more… www.troublefreepool.com
M Maldravus Well-known member Mar 16, 2025 189 Austin, Texas Pool Size 11282 Surface Fiberglass Chlorine Liquid Chlorine Today at 10:31 AM Add bookmark #424 HermanTX said: If you could not see the dot at 30 but can see at 40 then it is 40 Click to expand... I could see it at 40, but it was not a quick glance, it took me a couple seconds of looking. Not sure if that counts.
PoolStored TFP Expert Gold Supporter TFP Guide Jun 24, 2021 16,496 Ashtabula, OH Pool Size 29000 Surface Vinyl Chlorine Salt Water Generator SWG Type CircuPool RJ-60 Plus Today at 10:32 AM Add bookmark #425 HermanTX said: If you could not see the dot at 30 but can see at 40 then it is 40 Click to expand... Other way around…
