Hi from Texas
Just reporting back in here. 3 pucks dissolved. I still seem to be having to dose with LC according to Poolmath to 9ppm every day but clocking in ~5ppm during my tests. (Yesterday I dosed much later in the day than I normally do hence the 6.5 this morning). Add more pucks? Or is this just the way it is if I want to follow TFP?
Losing 3-5ppm of FC per day is norm especially as it gets warmer. Watch next week because weather states it will be HOT. So keep dosing to the 9ppm level to keep your FC in range.
If you continue to use pucks then test your CYA after 3-4 weeks of use to confirm your CYA level.
As some has said - your pool is like a puppy - it needs to be fed daily.
Does it register on the CYA test ? In the time it took, you may have added 9 and lost 5 to rain and/or degradation.
By trying to save money on using existing pucks, youre spending it on excess bleach.
Again, I get it, but you're robbing Peter to pay Paul here IMO. :)
Sorry, not following. I’ve only used 3 pucks following the suggestion here to raise my CYA by 10. I’m unsure how long that took but it’s probably been a couple weeks or longer. I had no plans to continue using pucks. Are you saying I should? I can retest CYA when my new reagents arrive.
We suggested you raise your CYA and you insisted on using the pucks you already had onhand, eventhough they'd be slow to make the changes.
OK great. It might not even register any different than it was, which would help explain why nothing changed with your daily loss.
Well it seems bizarre to spend even more money on CYA when the 50lbs of pucks I have add CYA. So is the suggestion to continue floating a single puck? Spend more money on CYA?
You're frustrated if you need to spend more money, you're frustrated if the other way takes time. Only you can decide which way frustrates you less. :)
Either works but both have a +/-. Let's see what CYA test says when you get it and go from there.
Reactions: oledan
