- Jun 12, 2011
- 3,769
- Plaster
- Pureline Crystal Pure 60,000
Stay out of pool stores. Their advice is incompatible with what we teach here. Their testing is not reliable. They will sell you overpriced magic potions, which in many cases are the same chemicals that can be purchased at your local grocery, hardware or big box store much cheaper, and in other cases are either unneeded or can cause more problems than they solve.
You are going to have to decide if you want to follow the Trouble Free Pool method, like thousands of very happy pool owners, or stick with pool store advice. The two methods incompatible, so you cannot mix the two. Our system is based on pure science. It starts with accurate testing. So each pool owner must have a good test kit, and know how to use it. Then we add exactly what, and only what is needed to the pool. You have to stop using pool store methods and chemicals and only add what is recommended here. There is a reason we recommend to only add bleach until you have your test kit, and we have test results.
We really do want to help you make yours another Trouble Free Pool.
