Of interest. I googled hayward E-100 and it said in one place that this filter/pump is for pools smaller than mine, like 15 x 24 , and for a 15 x 30 AG, the hayward E-200 is recommended, which has twice the flow rate and water turnover per hour, uses a 1.5HP pump, not a 1.0HP, and 200lbs of sand, not 100. So it appears that maybe the pool was set up by the original owner with a pump/filter that is a little on the small side for some reason. I am wondering if it might be worthwhile to replace the e-100 rig here with a new E-200 filter/1.5HP pump (about $600). I guess if everything works ok, there is no reason. Opinion?
