Ask them if the pipes/vessel was cleaned before filling. Ask them if they know the volume of water they are pumping. Don't point the nozzle in only one area that may cause washout.Thank you!!
I believe we will be using the hose but also having water trucked in to fill faster. Anything I should do it check when the water trucks start to fill the pool?
Most spas have 2 plumbing lines - one for the water and one for the air (from the air blower). Then then mix at the jet. That connection looks damaged.Anyone know if these are just structural or part of the blower or spa jets? Apparently they were damaged during the demo.
There seems to be one of those white pieces above every jet output. So I'm a little nervous...View attachment 573776View attachment 573777
You did the right thing. Chip out is labor intensive so that is the reason for additional cost. Keep us informed.Update: Apparently they were not planning on chipping out the old plaster. When the plasterer showed up he said the plaster was way too bad to just patch a few spots and had to chip out the entire pool. I thought this was the plan anyway. Although I had to pay more...
Congratulations on the grandchild birth. Hope Mother and Child are doing well.Question - I took a few days off to handle pool (also my second grandchild arrived yesterday. What a week!). Since I am a bit over eager, is it possible to brush too often? There is considerably less dust than I was expecting.
There could also be a start up instruction on the plaster mfg website. But the NPC guidelines are good as well.So the pool company only provided very minimal instructions. I decided to follow the NPC guidelines. Any issue with this? Is there anything folks on here disagree with?
Also, I really cannot use Polaris pressure side cleaner for a month? Anyone know why that would be the case? Just interested.
