We are currently pending permits for our new build. PB has been great to work with. Specs are below in signature. Depth starts at 3.5’, move to 5’, and back to 4’. I have seen several comments on TFP that 3.5’ is a bit too shallow. I inquired about the tweak with my PB, and he said it would be a no cost change, but advised against it. The reasoning being, the last step would be 18” rather than 12”, and that the area between the 3.5’ area and the 4’ area is negligible. To me, the 18” step would be an issue.
Are there any folks out there with 3.5’ that can offer insight?
On a separate note, I had PB remove cleaner/booster as I’m going to go robot route. They are going to plumb the pressure cleaner line and leave space on pad/pre-wire for booster if I decide to go that route in the future. I’m going to be giving Margaret at Marina a call. I’m leaning towards either S200 or S300i. I want, or think I want a GFI that is tied to the intellicenter that will run the robot. It’s my understanding the robot needs autonomous mode, which both of these have. I want a cart, and I dig the Bluetooth features of the 300i, but if I’m running through intellicenter, is there really any benefits?
