Ummm I'm a bit lost here ... Is this an outdoor install or part of the "basement monster" earlier in the thread??
Outside install. He was showing me an example for the sake of motivation. ;-)
UNIONS! Make sure to use unions so you can take things apart as needed to clean and repair. Just thought of that looking at your pics. I see the union on the filter but what about that long pipe?
How about sitting the filter on a concrete paver?
Probably better to replace the drain plug with a drain setup so you can drain tank to a place away from your equipment area. Whether you clean filters or just need to drain tank you need to get rid of waste
It looks like there is a union right at the filter body. The next union would be AFTER the valve to allow you to remove and set aside (WAY out of the way LOL) the value piece.
If heat bending you probably want to fill with sand to prevent buckling on the PVC
