Hi all,
Spring time and loads of pollen on the surface of my water. Even with my pump turned up to cleaning mode/high speed, the skimmer just doesn't get the tiny bits of pollen off the surface. I read in the forums that a possible solution would be to adjust the valves so that my skimmer is doing more of the work than the floor drains. But I'm not sure which valve does that. Hoping that someone can help shed some light with the attached photos. Let me know if you need a better angle.
Thanks!
Matt
Thanks!
Matt
