Hi Guys,
I'm building an automated acid feeder and I would LOVE any Jedi wisdom you can contribute to this project.
The system will use:
I know programming so I would setup my Arduino controller to read the ph readings and then dose the pool based on the acid demand - keeping the ph of the water always where it needs to be.
I would 'tap' into the pvc pool plumbing to inject the acid. I've already done this part and it works well. No leaks. I already have the arduino controller and the ph probe. I've already built a sensor assembly for the probe where water flows into it (where the probe is submerged in the flowing water) and is constantly sending ph readings to the controller.
What I'm undecided about is how to move the acid from the acid tank into the pool plumbing. Can you give me your Jedi wisdom/experience? I don't doubt that I may be overlooking easier options due to inexperience.
Here are some options I have so far...
Option 1: Solenoid Valve. My initial idea was to 'tap' into the inlet pipe of the pump, connect plastic tubing from that to a solenoid which is connected via tubing the the acid tank. My controller would open the solenoid and the suction from the pump would pull in the acid. Yes, acid is corrosive to the pool equipment but I intend to use many tiny doses which should result in the acid being heavily diluted before it reaches the equipment. Also, I could always dilute the acid in the tank with water to reduce the acidic impact even further.
The upside is that these things would be easy to hookup with their quick-connect tube fittings, are inexpensive and will rarely fail (there's not many moving parts).
The downside is that I'm having trouble finding one that won't corrode with the muriatic acid (the plunger in the solenoid is made of stainless steel which apparently doesn't fare well with the acid). If I could find one that did, it would be perfect.
Option 2: Peristaltic Pump. Another option is the peristaltic pump. I do believe these are made of plastic so should hold up better to the acid.
One upside is that since it is a pump and can move the acid without needing to use the pool pump, I can probably tap into the return return side of the plumbing after the equipment instead of the inlet side (so the acid will not flow through the equipment).
A downside is that these have many more moving parts and I assume they will need to be repaired/replaced more often.
I would LOVE to hear what suggestions you may have.
Questions:
Thanks!
John
- a ph probe,
- an arduino controller board,
- and a tank of acid
Questions:
- Do you know where I can find a solenoid that isn't corroded by the muriatic acid?
- I'm think the stainless steel plunger solenoid valves would probably last several months. They've fairly inexpensive and extremely easy to replace so I wouldn't mind replacing them every 6 months or so. But my concern is that the corroded metal flakes off and ends up in the water causing staining on the pool surface. Is that a valid concern or am I overthinking this?
- Do you know of any OTHER solutions/options that I should consider?
Thanks!
John
