- Jun 22, 2014
- 48,922
- Fiberglass
- CircuPool RJ-45 Plus
Okay madyogi, I haven't visited your thread for over 2 weeks now because of helping other members, and honestly, it appeared you had lots of help with others jumping in. But after taking a peek at what's been happening, I have to say something's not right. Before I get into the SLAM itself, let me first say to you and everyone else who's been so wonderful in helping madyogi .... we have to be careful about hijacking a thread. This is madyogi's thread, and I can see where it's become derailed and is now a story about 2-3 pools, and that's never good. My gut tells me to split thins off to your own threads, but you all seem to be having a good time and getting long which is what we always want to see. So I'll leave things for now because honestly, it would be a lot of work for me to split posts, but if any of you want me to do that, just let me know and I will.
Now for madyogi's water ...... I don't like it for two reasons: The color (hue) of that green and the cloudiness. I never saw the initial green until today, and it seems borderline iron and algae. Very close. So I would like to ask the following
1. Have you ever been told there is iron in your water? I wouldn't think in LR you would. My daughters live in Cabot and I would expect they might, but in LR you never know.
2. Are you filling from a well? If not, you might also consider checking with the water district. Their annual report should disclose any metals.
3. At some point when you get a chance, I'd like you to take a water sample, not from the pool but from your fill hose, and get a free pool store test. Yes, I said it. Just ignore all the chatter and advice, say thank you, and go about your way. Let us know what your iron content is (if any). I'd feel better to know for sure.
Filtration - There is a LOT of talk about additional filtration in this thread. I understand why it is so attractive and how it may have its benefits, but I'm here to tell you ..... when you have algae it has to be chemically destroyed first. No additional filtration will cure a green pool. Nether will DE for that matter which is another item that has popped its ugly head early on. DE is fine once the pool is almost clear and blue and passing he OCLT, but not at this stage. Focus on the chemicals (FC & CYA) first. I couldn't tell earlier though when you discussed the deep clean ... did you ever do it? If not, I do believe that's something you should ensure gets done to dislodge any old junk trapped in the sand. The sand may also be compacted from years of use and become "channeled" in ways the inhibits good sand filtration throughout.
Chemicals - I think I asked this earlier in May when I first chimed in, but to make sure .... other than regular bleach, muriatic acid, and stabilizer, have you added ANYTHING else to that water you can think of? Any pool store products of any type? If the answer is no, and if you learn there is no significant amount of iron in the water, you still have an FC/CYA imbalance - no question. Even if you have iron, the water should be clear by now with a tint to it. But honestly I'm not seeing any improvements, and this has been way too long. I would recommend another CYA test using the following to assist:
Madyogi, it's also important for you to understand you are not the only one who struggles with testing accuracy. We all do. Just last night I was upset at myself for not reading my CH properly, even with a speedstir. Sometimes the color changes or appearance of the dot (in the case of your CYA) is frustrating, but you can do it. Like I note above, use that same sample and go back & forth 2 times or 20 times, it doesn't matter. Just keep pouring and viewing until you are 100% confident you have a good/consistent CYA. The entire concept and success of your SLAM rests on that CYA test. As you know, if the CYA is higher than you thought, the bleach isn't able to work strong enough. If the CYA is lower than you thought, like when it was below 30, the AR sun is impeding your progress. So if the sun is out today, make sure to verify that CYA.
Just remember ... algae cannot survive in a properly sanitized body of water. To see algae means either the FC/CYA ratio is off, or you still have an undiscovered body of algae in your pool you haven't brushed or found yet. By now I would think you had brushed every inch of the pool 40+ times, but if algae is tucked away in some hollow steps, ladder, or behind a light, it will get you. If there is any chance there is still some bulk material laying at the bottom, it must be removed.
I'll try to pop back in and monitor your progress as times permits, so please reply back with some answers to those questions above and let me/us know if you have any questions. To everyone who has chimed in to help madyogi, thank you. It's nice to see everyone helping. At the same time, be mindful of madyogi's thread and lets try to keep the focus on their pool. If you want my help to clean things up on this thread, just let me know. Thanks everyone, and have a great Friday/weekend.
CYA Testing:
Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Use the mixing bottle to gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Recommend standing outside with your back to the sun and the view tube in the shade of your body at waist level. Then, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. To help the eyes and prevent staring at the dot, some people find it better to pour & view in stages. Pour some solution into the viewing tube, look away, then look back again for the dot. Repeat as necessary until you feel the dot is gone. After the first CYA test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, gently shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate your own CYA reading.
