Hello! My Hayward sand filter is leaking so I went to the pool store and got a new clamp and O-ring. Guy said to replace the ring I must “cut through the plumbing” and lift out the valve to access the ring. That I can do. However, how does one plumb it back to working order? There’s three PVC pipes going in that will need to be cut. How do I do the plumbing after I’ve replaced the O-ring and screwed on the clamp? Please see photos for clarification and thanks in advance for any advice you may have to offer. Eric
