In a nutshell. I bought a home with existing spa. Pump is fried. I brought my pool equipment from my old house. New home has 1.5” plumbing. Old equiptment is 2”. Can I hook up my Superflo 1.5 VS and filter to nee equipment without changing plumbing from pump to outlet? Basically will have a 1.5” inlet into the pump. 2” from pump to filter, 2” from filter to outlet in the ground. Do a pvc reducer 2” to 1.5” at the ground outlet? I feel it should be fine, but would like to get some opinions from experience. Thank you
