View attachment 67045Hello! I currently have a 10 year old heater, that needs replacement. When we moved in, the pool had not been used in quite some time, so many things required repair and/or cleaning. The heater seemed to work well the first year, then late last year, it started to go on and off intermittently, and more concerning there were times when the gas would build up outside the heater and ignite at once, causing a rather loud boom. We found a leak in the pilot tubing, had that replaced, and everything worked well for a year, and now we are having all sorts of issues. At this point, I don't want to continue to try and repair this unit, as it is significantly damaged due to salt water corrosion and rust (photo below)
Here are my questions, I am open to any and all advice....
My pool guy, whom I like, is recommending a RayPak 406k BTU. I did some research on this site, and this unit is very well liked. Before I buy and have it installed (it is around $3k installed), I just want to make sure there aren't any other great ideas or options.
Second, if you look at the photo of my current heater, you will see fairly significant damage to the bottom area, and that corrosion is very noticeable inside the unit as well. I believe this to be due to the salt water that comes out of my pool equipment rather frequently.
When we first moved in, I did some things to try and reduce the amount of salt water that would come in contact with the pool. For example, the backwash drain emptied right at the heater. I added a 15 foot piece of tubing to divert that down the yard. This was the biggest change, but even with that and other changes, there is still salt water that flows down and comes in contact with the heater (small leaks in the joints, when I got to empty the pump basket, when we changed the salt water generator, etc...)
I would think it best to elevate the new heater a few inches off that concrete slab to allow any salt water to flow below it, but that might also require re-plumbing of the water and gas lines, so that they "line up".
Has anyone had similar issue, or does anyone have any good ideas to remedy this salt water coming in contact with a heater issue? I would like the new heater to last a long time, so those are the tips I am looking for. Thank you all in advance!
