I figured I'd go to the best source I know for help....
I just installed a Hayward Max-Flo VS Pump (1.65 hp) and have run into a head scratcher for me. When running at it's highest speed (3,250 rpm), the pressure on my filter is about 18, when it drops down to speed 2 (1,750 rpm) the pressure is basically zero. This is a stark contrast from the 24 - 30 that it typically ran at with the 1.5hp single speed pump I just replaced. I also noticed that at both speeds the water is not circulating in the pool very well albeit much better at speed 4 (3250 rpm) and closer to what I was used to with the old pump (which completely died btw hence the replacement).
Since I was stumped, I decided to double check everything, I ended up taking apart the filter and completely cleaned the grids so that there was no assumed blockage. After getting everything back up and running there was no difference in the pressures at the different speeds. When I check the skimmer suction, there was plenty that I felt (although I never checked that by hand before so I can't really compare to the old single speed pump). I'm wondering if anyone has had any experience with this? My biggest concern is that i didn't buy the correct pump for my sized pool. The other thought is that the filter is undersized? Not really sure about anything at this point. Any and all help is greatly appreciated!!!
