First, I would like to thank the TFP community for all the knowledge I have gained since discovering this site.
I finally have a problem that I am unsure how to tackle.
I live in the Phoenix valley. The pool is in full sun.
I have high CH in my fill water. Generally, about 200 ppm.
My CH increases about 300ppm per year. Currently it is at 1000 ppm.
My CSI is always kept between -.1 and 0.
Current test results:
FC-5.5
PH-7.7
TA-50
CH-1000
CYA-70
Salt-3400
Borate~45
Temp 92
CSI- (-.06)
I have recently lowered my TA from 60 to 50 to slow pH rise. (I see that is now considered acceptable by Pool Math.) I was thinking of lowering it even more based on how my hot tub reacts to low TA.
However, I am now getting calcium buildup on surfaces that get splashed on. (Below waterfall and around sprinkler.) No buildup at water line.
I am sure I will need to drain and refill this winter.
Do you think lowering the TA had anything to do with this?
I hear that pools can be maintained at even higher CH levels. Do they all exhibit this Calcium precipitation on above water line surfaces?
Thanks in advance for your replies.
Bruce
FC-5.5
PH-7.7
TA-50
CH-1000
CYA-70
Salt-3400
Borate~45
Temp 92
CSI- (-.06)
Bruce
