Hello - I have a waterfall feature in my pool and when I either click the Waterfall feature button on my EasyTouch 8 or my ScreenLogic, the pump fires up, the Pentair CVA-24 actuator switches the Jandy Valve to divert water to the waterfall, and water starts flowing out of the waterfall. It has been working great for the past 2 years. Just this week, when I have pressed the Waterfall feature button, the pump fires up... but the actuator no longer switches the valve to divert water to the waterfall. I have been able to use the motorized switch on the side of the actuator to adjust the valve open and closed (using the "UP" and "DOWN" positions) and that gets the waterfall going when I need it. While I'm happy to see the motor in the CVA-24 is operable, I really want to be able to click the Waterfall button again and turn the waterfall on/off wherever I am. Any thoughts on what might be causing the disconnect between the EasyTouch 8 and the Pentair CVA-24 actuator? Thanks!
