Hello,
On the weekend I discovered 2 holes in my liner. 1 in the shallow end that was the size of a quarter and 1 in the deep in that was about 1cm slit. Both are patched and seem to be holding.
Now, how do I get the water out from behind the liner. The pool compnay that I use to open and close only said it is a simple process that I can do myself. I pull the liner and use my pool pump and hose to suck out the water.
Have not tried as of yet, but when I hook everything up to the skimmer and put the hose down behind the liner will the hose just not dump the water out and cause a massive air pocket before it can start sucking at the bottom of the pool?
Can someone explain the process or would it be easier to get a small self prime pump and use garden hose to pull the water and another to put it back into the pool or is using the pool pump very easy?
thanks,
thanks,
