- Jun 7, 2017
- 9,178
- Plaster
- Jandy Aquapure 1400
Bottom line is there needs to be a gap between the water and the skimmer opening (the opening at the top of the skimmer flap) to allow floating debris to collect in the skimmer. As long as there is some sort of gap, your skimmer should work. But with your pics, it appears that the water level will be at or above the top of the skimmer opening. This is what needs to be clarified. Stand in your pool and look eye level (or use an actual level) into the skimmer where your water level will be and see if there is a gap between the water line and the skimmer.
