“Unbalanced backfill height.
Unbalanced backfill height is the difference in height between the exterior finish ground level and the lower of the top of the concrete footing that supports the foundation wall…”
ICC Digital Codes is the largest provider of model codes, custom codes and standards used worldwide to construct safe, sustainable, affordable and resilient structures.
codes.iccsafe.org
Based on MY interpretation (assuming your pool is deeper than 2 ft under ground) your code enforcer requires your pool plans to be designed and sealed by a registered professional (structural) engineer in your state.
