Help, totally screwed, need NJ references
Klf
1
NJ
I was in the middle of a pool build and the company XXX filed for bankruptcy and my job is a total halt. I had another company come to view the job and they said the pool looked structurally unsound. Who can I get to inspect this to see if this is sound? Also seeking other companies to help finish this project.
JoyfulNoise
Platinum Supporter
May 23, 2015
15,861
Does NJ have a contractor licensing board? If so and the previous contractor was licensed, they may be able to help you out in finding a new pool builder.
The main problem is most pool builders have booked their work for the season and are not likely to have the room in their schedules. So you’ll definitely need to adjust expectations when it comes to project completion. You could be looking at a hole on your yard for quite a while.
Sorry this happened to you. It stinks but it’s a risk when it comes to building a pool.
ajw22
10,486
Northern NJ
Like others have asked - where in NJ? I think we have you covered between South, Central, and North.
@jimmythegreek is in the area
Pics of where your build is can help us understand your situation.
jimmythegreek
In The Industry
Aug 10, 2017
1,339
Morris Cnty NJ
I have an expert I use for when I'm called in to legal arbitrations and its outside my scope of expertise. Where in NJ are you and can you send/post some pics I can take a look and give u some advice
