Need help in deciding the right pool light fixture that is either long lasting or easy to replace with bulbs. Looks like the following are the key options:
1) Use Pentair Amerlite fixture and replace with LED bulbs. Has anyone used a 12V LED on this fixture from this vendor?
www.florida-sunseeker.com
2) Other option is to just go for 12V Pentair Arch Series Color LEDs. I read about Intellibrite 5G having some reliability issues and wanted to see if anyone has used this. Also they advertise improved lighting -- brightness / even light. Is this going to be visible?
bestbuypoolsupply.com
3) Have anyone used these LEDs (fixtures with replaceable bulbs)? How good is the light quality?
Thanks!
PoolTone⢠12V Color LED Pool Replacement Bulb 18 or 35 Watts for Pentair® Amerlite®
This bulb is designed to fit American Pool Products® and Pentair® Amerilite® Pool Fixtures that run at 12 Volts REPLACEMENT COLOR CHANGING LED POOL & SPA LIGHTS Color replacement LED pool bulb offers seven solid colors, and nine light shows that can instantly transform your pool area into a...
Pentair 602152 50' 12V LED Color Pool Intellibrite Architectural Series Light
Elevate nighttime pool experiences with the next generation of LED underwater pool lighting. The Intellibrite Architectural Series Lights deliver a more dazzling and dynamic LED pool lighting experience with a brighter light and greater energy efficiency.
PoolTone⢠Standard 16 Color LED Pool Light 12 or 120V 15-150 FT Cord
16 Color/Show Underwater Pool Light Direct replacement Pentair Amerlite with Pool Tone Color LED fully assembled install Pool Tone 75 - 300% brighter OEM 5G fixtures. fit all standard 8" pool niche
Thanks!
