Help rewiring my Intellichlor IC40 correctly
poolboytex
2
Houston
Hi – first time poster on this forum. I have already read a few great posts on here about Intellichlor/EasyTouch installations but I still have a few questions about my setup. We inherited the setup from the previous owners. It’s an EasyTouch 8 with an Intellichlor IC40 SWG and Sta-rite Intellipro VSF pump. There are pool lights, spa, and a heater connected as well. From what I can tell, the installers did not wire the SWG correctly as the SWG stays powered on when the VSF pump is off. The SWG transformer was powered directly from a 15amp breaker in the load center (circled in RED in the picture) and not connected to the load side of the Filter Pump Relay (circled in GREEN).
Trying to correct the issue, I moved the yellow and white wires coming out of the left side of the SWG transformer from the 15amp breaker (circled in RED) and connected them to the load side of the Filter Pump Relay. But now my question is, do I move the two black wires from the VSF pump (currently connected to the 20amp breaker circled in YELLOW) to the load side of the Filter Pump Relay, and then wire the line side of the Filter Pump Relay to the 20amp breaker where the two black wires from the VSF pump used to be?
Thanks.
Welcome to TFP.
You wire the pump CB to the LINE side of the filter pump relay putting the wires on the left side of each screw.
And connect the black wires from the pump to the LINE side of the pump relay putting the wires on the right side of the screw.
That way your pump has constant power and your SWG has switched power.
@ajw22 - thank you so much for your quick and clear reply! I finished rewiring it this afternoon and everything is working as it should. Pump off, SWG off. Pump on, SWG on. This was apparently incorrectly installed by the pool builder's electrician when the pool was put in 5 years ago ... not impressed. Very happy it's fixed now. Thanks again.
Reactions: JamesW
Glad it worked out.
We are all volunteers. TFP is a registered 501(c)3 non-profit that is kept online by user donations. . Please consider donating at Support TFP!.
Reactions: poolboytex
