My house lost power very briefly but for some reason it caused my pool pump to shut off (low voltage code). I flipped the breaker and that fixed the pool pump issue (seemed to reset itself) and the pool pump is now running fine. However, my Pentair Ultratemp heat pump still has the red service light on with the "low water flow alarm" on the screen. The heater has been working fine prior to this power outage so I suspect all that is going on is that when the pool pump stopped working, the heat pump sensed low water flow (understandably) and threw a code. Now though I don't know how to get the heat pump to reset itself and recheck the water flow (which should now be fine since the pool pump is running).
Long way of asking, does anyone know if there's a way to "reset" a Pentair Ultratemp heat pump or clear a code so that it rechecks things and sees they're working again? I've already tried flipping the breaker off then on, and the "On/Off" button on the heat pump screen does nothing.
