I have been trying for a month to fix the chemicals in the pool with a green pool. After two trips to dover pools I'm getting mad because I have followed their tips. Here is where I am now. Saturday night we floc the pool as instructed ran for 2 hours and turned salt system off. All chemicals were normal. After vaccuming from floc to backwash we had to add water. Chemicals needed new balancing started from the top as dover pools said checking calcium hardness, then alkaline, both good numbers went to ph followed the dosing they told us to add 19 oz adding 9 ounces at a time was coming up and then we went to chlorine and added 2 bags of shock and now that's good but the ph has dropped. Pool has started to turn greenish but still can see the bottom. Cya is now low. Please any advice.
