HELP Please! New iAqualink Rs4 system board not turning on
mihzyd777
221
Manteca, CA
Pentair Intellichlor IC-40
Hi All,
Hope you can help me out. Added a new actuator valve and everything working right. Also, setup pool lights on program to come on with 1 touch setting. Notice when I turned lights on it was just click where they were working fine for about a week now. I turned off the brekaer and took the Aux 1 and Aux 2 , 2-pin connectors and swapped them thinking that's where issue was. I turned breaker back on and now aqualink board won't power on at all.
So did I break something when I swapped Aux 1 with Aux 2 connectors on the board? Or could the relay have gone bad?m and how can I check it with a meter? Just fyi I didn't mess with the filter pump relay/connector.
Any ideas?
Thank you!
Thanks
mihzyd777
221
Manteca, CA
Figured it out. The plug on the side of the box had the GFCI trip. Reset and working again :)
