While your pH did appear to be low previously, we don't know how low or for how long, so we could be making some assumptions. But with no algaecides used, if it is copper staining, Marty is probably correct on that heat exchanger getting corroded. For now, the higher CH may be helping a bit to compensate .... at least for the pebble-Tech. But that TA does need to come up a bit to 50-60 at least. So you have no loop or way to isolate the heater huh? If the suspected copper is from the heater exchange, and no way to isolate the heater, that will be something you'll want to have checked to see if repairs are needed.
It's odd that you showed an FC of 10 yesterday afternoon and then only a 1 early this morning. Either the testing was off or you have a major algae issue with all the FC consumption. I would double-check. If the FC is that low, I would increase the FC right away to be balanced with your current CYA as listed on the [FC/CYA][/FC/CYA]. Next time you post your test results, please post them as follows:
FC
CC
CYA
PH
TA
CH
Now that your sig is updated, have you been using the SWG exclusively, or have you added any other methods of chlorine?
