Recently had our pool company install a new Pentair MasterTemp 150 to replace a 20 year old heater and was excited to add on a Pentair Intelliconnect for easy pool temp monitoring. Currently winter here in NJ, so we've kept the Intelliconnect in Service mode and nothing has been running. Separate water temp sensor installed which keeps track of current water temp very accurately (even if there's no water flowing currently, it's always within 1 or 2 degrees of the air sensor reading, which comes from real time data.)
I noticed last week that the water temp had stayed at the same temp for 7 days straight, which was quite odd since the air temp had fluctuated +/- 20 degrees. I flip the breaker for the entire system for a few minutes, turn it back on, and it kicks in with the new, correct, water temp, so the sensor is definitely measuring correctly. It seems like now the water temp is still not updating in real time, and needs to have the power shut off and turned back on to update the water temp.
Anyone run into this problem? Not sure if it's the water sensor or the Intelliconnect not pushing real time water temp updates It had worked initially, even in service mode, and would constantly update the water temp, but it now it needs a full restart every time.
Link light and service light are solid green, so the connection is good.
