We cleaned the cartridge filters today and I turned the filter off and then turned off the breakers. (Didn’t put it in service mode.)
When we put the cleaned cartridges back we noticed the water in the tank was all gross. I asked my neighbor what to do with this water and he said scoop it out. So we did just that. When we put everything back together, water is not running through the system now. We are not sure if we should keep the filter running and eventually water will come through, or if we need to fill the tank back up with water? We don’t know what happened!
Slightly panicked. Obviously first time pool owner here. The first time we cleaned the filter, the pool company came out and showed us what to do, but left us to do it ourselves. He had to come back and help me reassemble it because I was having trouble. .
This time my husband reassembled it and I’m not sure what went wrong.
We have a Hayward variable pump if that is relevant.
Edit: we fixed the issue! We forgot to prime the pump before turning it back on!
