help needed
Traviz02
94
Southeast Missouri
took cover off of pool about a week ago and water was clear-within the last week it has turned green-pool is not running yet so im sure that is why,curious how much chlorine should i put in without it running to try and clear it up thank you in advance
Pour one or two gallons of 10% liquid chlorine in daily and stir the water with your pool brush until you get your pump running.
Then do a full set of tests and follow the SLAM Process
