Help needed in grand prairie.
Juggalo_931
Active member
Apr 20, 2019
38
Grand Prairie, TX
Somewhat new to this. Have to replace a liner for the first time and have no real idea what im doing. My pool says esther williams on some of the pieces but no idea if the liner is one. Any ES experienced people with free time willing to help me out?
kimkats
41,310
Tallahassee, FL
Do it on a hot day so the liner is nice and warm and can be easily manipulated and moved.
Here is a link to some how tos that I like: Search for: installing liner - INYOPools.com I was not sure if your pool is round or oval so did not want to only what one link.
Some friends are needed IF they can follow directions and work as a team. A promise of beers and grilled food goes a long way in finding said friends LOL
Kim:kim:
woodyp
10,576
East Texas
Those two are largely just personal choices...especially the second. What's under it now? Are you happy with it?
kimkats
41,310
Tallahassee, FL
I don't have the wall foam as I worry about it holding moisture against the wall and causing it to rust faster. For the floor I just have hand packed sand.
Kim:kim:
kimkats
41,310
Tallahassee, FL
Take picture that really shows how it is held on and share it here. I will ping someone who will know how to help you with this part of it.
kimkats
41,310
Tallahassee, FL
The "sting" looking stuff is called "liner lock". I have it on my pool. It helps hold the liner in the track.
I am going to call my guy in now..... @InyoRob He will get you all set up for what liner to order!!!
Kim:kim:
kimkats
41,310
Tallahassee, FL
Okay now we have to go old school! Popsicle sticks!!! WHAT??? Yeah you can use good, old fashion Popsicle sticks to help hold the liner in the hanger. You might need to use the sticks AND the sticks to hold the liner in good. You can buy them at any craft shop.
I don't know if there are different sized of liner lock. Will have to ask @InyoRob
Kim:kim:
InyoRob
136
Longwood/FL
If you can remove the bead receiver, I'd recommend a j-hook/unibead type liner. Those liners have a thick rubber hook at the top that hangs on the pool wall. They are easy to install and you don't have to worry about using the liner lock or popsicle sticks. The downside is that you have to remove the top rails in order to replace the liner.
Reactions: Juggalo_931
